Ana içeriğe geç
Roborock Q5 Pro: Laser Distance Sensor Replacement
Neye ihtiyacın var
  1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: adım 1, 3 resimden 1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: adım 1, 3 resimden 2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the dustbin.: adım 1, 3 resimden 3.
    • Flip it on its head, then remove the dustbin.
  2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bottom cover.: adım 2, 2 resimden 1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bottom cover.: adım 2, 2 resimden 2.
    • Remove the side brush using a PH2 screwdriver.
    • Remove the screws using a PH2 screwdriver.
    • Then, pull the bottom cover off.
  3. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: adım 3, 3 resimden 1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: adım 3, 3 resimden 2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the battery.: adım 3, 3 resimden 3.
    • Lift it up on the left.
    • Detach the connector by squeezing the release tab, then pull it out.
    • Do not simply yank the battery out. You will tear the connector off the motherboard.
  4. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper's lid.: adım 4, 2 resimden 1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper's lid.: adım 4, 2 resimden 2.
    • Remove the marked screws using a PH1 screwdriver.
    • Then simply lift the lid off.
  5. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper.: adım 5, 2 resimden 1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the bumper.: adım 5, 2 resimden 2.
    • Flip the robot over.
    • Tilt the bumper forwards and move it upwards to remove it.
  6. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the side brush motor.: adım 6, 1 resimden 1.
    • Flip it back over.
    • Simply lift it out.
  7. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the chassis screws.: adım 7, 1 resimden 1.
    • Remove the marked screws using a PH2 screwdriver.
  8. Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: adım 8, 3 resimden 1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: adım 8, 3 resimden 2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Latches.: adım 8, 3 resimden 3.
    • The chassis will still be held together by a couple latches on the back.
    • Use a prying tool to get these apart before taking it apart.
  9. Roborock Q5 Pro: Laser Distance Sensor Replacement, Take it apart!: adım 9, 2 resimden 1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Take it apart!: adım 9, 2 resimden 2.
    • Flip it over and simply pull the chassis halves apart.
  10. Roborock Q5 Pro: Laser Distance Sensor Replacement, Screeeeeeews.: adım 10, 1 resimden 1.
    • Here are the screws organised by steps and type.
    • Use this if needed as a reference during reassembly.
  11. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: adım 11, 3 resimden 1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: adım 11, 3 resimden 2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS cage.: adım 11, 3 resimden 3.
    • Then, remove it.
  12. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: adım 12, 3 resimden 1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: adım 12, 3 resimden 2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the LDS.: adım 12, 3 resimden 3.
    • Lift the LDS towards the right, then disconnect the connector.
    • If you're replacing the LDS, simply insert the new one and reassemble your device.
  13. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: adım 13, 3 resimden 1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: adım 13, 3 resimden 2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the rubber band.: adım 13, 3 resimden 3.
    • Remove the rubber band using some tweezers, forceps or your fingers.
    • Make sure to clean it. This one was quite dirty, which was causing the motor to seize.
    • Your robot may have a different iteration of the LDS, which has a cover over the rubber band section. In that case, please check: Roborock Q Revo: Laser Distance Sensor Replacement and skip to step 12.
  14. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: adım 14, 3 resimden 1. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: adım 14, 3 resimden 2. Roborock Q5 Pro: Laser Distance Sensor Replacement, Remove the motor.: adım 14, 3 resimden 3.
    • Before removing the motor, flip it over and check whether it has a connector or is soldered directly onto the PCBA.
    • Remove the screws.
    • Now you can remove and replace the motor.
    • Your robot may have a different iteration of the LDS, which needs it's driving wheel removed before you can remove the screws. In that case, please check: Roborock Q Revo: Laser Distance Sensor Replacement and skip to step 12.
Sonuç
Bir başkası bu kılavuzu tamamladı.
DegenFixer
5.081 İtibar
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 88
Son 30 gün: 455
Her zaman: 4,797
