Ana içeriğe geç
Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement
Neye ihtiyacın var
  1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: adım 1, 1 resimden 1.
    • Remove the 4 rubber tabs on the bottom side of the receiver.
    FixBot'a Sor
    Yorum Ekle
  2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: adım 2, 1 resimden 1.
    • Unscrew the four 12 mm screws on the bottom side of the receiver.
    • Use a Phillips #1 screwdriver for this step.
    FixBot'a Sor
    Yorum Ekle
  3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: adım 3, 2 resimden 1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: adım 3, 2 resimden 2.
    • Remove top casing from the receiver.
    • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
    FixBot'a Sor
    Yorum Ekle
  4. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, Receiver Wireless Audio Module Chip: adım 4, 1 resimden 1.
    • Unscrew the 10 mm screw holding the wireless audio module.
    FixBot'a Sor
    Yorum Ekle
  5. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: adım 5, 2 resimden 1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Slide the black retaining flap securing the ribbon cable away from the white bar.
    • There should be only a small space between the white bar and black retaining flap.
    • You may want to use tweezers for this step.
    FixBot'a Sor
    Yorum Ekle
  6. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: adım 6, 1 resimden 1.
    • Using your fingers, slide the ribbon cable out from the under the black retaining flap to completely disconnect it from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To install the new wireless audio module chip, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Caitlin Charlton
756 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-2, Williams Spring 2015 Baylor, Team 4-2, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G2
3 Üyeler
1Rehber Yorum
This is a very long time later, but where do you get the receiver chip??? Rocket fish doesn't support the product anymore
Michael Jay - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 2,541
