Ana içeriğe geç
Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement
Neye ihtiyacın var
  1. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Sender: adım 1, 1 resimden 1.
    • Remove the four rubber tabs from the bottom of the sender.
    • Pull hard to peel off the rubber tabs, as they are attached with adhesive.
    FixBot'a Sor
    Yorum Ekle
  2. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to unscrew the four 12 mm screws on the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: adım 3, 2 resimden 1. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: adım 3, 2 resimden 2.
    • Flip the device over and remove the top casing from the sender.
    FixBot'a Sor
    Yorum Ekle
  4. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement, Sender Wireless Audio Module Chip: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the wireless audio module chip.
    FixBot'a Sor
    Yorum Ekle
  5. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #1 screwdriver to unscrew the two 10 mm screws located on either side of the speakers.
    • Secure the front speaker input terminal to release the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: adım 7, 2 resimden 1. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: adım 7, 2 resimden 2.
    • Using both thumbs, push the front speaker input terminal back towards the inside part of the device.
    FixBot'a Sor
    Yorum Ekle
  8. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: adım 8, 1 resimden 1.
    • Flip over the motherboard and wireless audio module chip.
    FixBot'a Sor
    Yorum Ekle
  9. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Gently slide the black retaining flap back, securing the ribbon wire gently away from the white bar.
    • There should only be a small separation between the white bar and the black retaining flap.
    • Tweezers are recommended for this step.
    FixBot'a Sor
    Yorum Ekle
  10. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: adım 10, 1 resimden 1.
    • Using your fingers, pull the ribbon wire out from the black retaining flap in order to completely disconnect the wireless audio module chip.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To install the new wireless module chip, follow these instructions in reverse order.
Once the sender has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new wireless module chip has been properly assembled.
Caitlin Charlton
756 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-2, Williams Spring 2015 Baylor, Team 4-2, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G2
3 Üyeler
3Kılavuz Yorumları
Does Rocketfish offer a replacement board?
Bob David - Yanıt Paylaş
“No Parts Required” is a joke . Where are the replacement boards available from?
Petie Martin - Yanıt Paylaş
I used the wrong ac adapter, which worked for a few weeks then the unit died and won't power on. Would anyone know what I should check out with the multi meter to see what's wrong and see if I can fix it? Thanks!
Adam Sawicki - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 41
Her zaman: 1,906
