Ana içeriğe geç
Roku 2 Case Replacement
Neye ihtiyacın var
  1. Roku 2 Case Replacement, Case: adım 1, 1 resimden 1.
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • Note: It may take several heats, left for a minute at a time, to loosen the glue.
  2. Roku 2 Case Replacement: adım 2, 1 resimden 1.
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2 Case Replacement: adım 3, 1 resimden 1.
    • Use the 000 phillips to remove the screws found under all four of the rubber pads.
  4. Roku 2 Case Replacement: adım 4, 1 resimden 1.
    • Gently remove the under side of the device.
  5. Roku 2 Case Replacement: adım 5, 1 resimden 1.
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2 Case Replacement: adım 6, 1 resimden 1.
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2 Case Replacement: adım 7, 1 resimden 1.
    • Remove the board from the plastic enclosure and put the board into the replacement enclosure.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eric Rawls
360 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S1G5
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
cause mine get’s hot and it’s slow as !&&*
brian price - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 737
