Ana içeriğe geç
Roku 3 Motherboard Replacement
Neye ihtiyacın var
  1. Roku 3 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
  2. Roku 3 Motherboard Replacement: adım 2, 3 resimden 1. Roku 3 Motherboard Replacement: adım 2, 3 resimden 2. Roku 3 Motherboard Replacement: adım 2, 3 resimden 3.
    • Pull back the rubber protection in the top right corner to locate the screw.
    • Repeat with the bottom right corner and bottom left corner.
  3. Roku 3 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
  4. Roku 3 Motherboard Replacement: adım 4, 2 resimden 1. Roku 3 Motherboard Replacement: adım 4, 2 resimden 2.
    • Open the device by gently lifting the bottom half away from the top half of the device.
  5. Roku 3 Motherboard Replacement: adım 5, 1 resimden 1.
    • Use your fingers to carefully lift the motherboard from the top half of the device.
  6. Roku 3 Motherboard Replacement: adım 6, 2 resimden 1. Roku 3 Motherboard Replacement: adım 6, 2 resimden 2.
    • Pull away the IO shield from the motherboard using your hands.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Samantha Miller
290 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-2, Livingston Fall 2016 Cal Poly, Team 15-2, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G2
3 Üyeler
6 adet Kılavuz yazıldı
3 Yorum
Buenas tardes exelente guía
Elias Herrera - Yanıt
Great where to you get the motherboard?
Joseph Pigott - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 18
Her zaman: 5,730
