Ana içeriğe geç
Roku 3 Remote Control Motherboard Replacement
Neye ihtiyacın var
  1. Roku 3 Remote Control Motherboard Replacement, Remote Control Battery: adım 1, 1 resimden 1.
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
  2. Roku 3 Remote Control Motherboard Replacement: adım 2, 2 resimden 1. Roku 3 Remote Control Motherboard Replacement: adım 2, 2 resimden 2.
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
  3. Roku 3 Remote Control Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
  4. Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: adım 4, 2 resimden 1. Roku 3 Remote Control Motherboard Replacement, Remote Control Motherboard: adım 4, 2 resimden 2.
    • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
  5. Roku 3 Remote Control Motherboard Replacement: adım 5, 2 resimden 1. Roku 3 Remote Control Motherboard Replacement: adım 5, 2 resimden 2.
    • Gently pry open the remote using the plastic opening tool.
  6. Roku 3 Remote Control Motherboard Replacement: adım 6, 2 resimden 1. Roku 3 Remote Control Motherboard Replacement: adım 6, 2 resimden 2.
    • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
    • Separate the top and bottom of the remote casing.
    • Gently place each half of the remote onto a table so that the exteriors are face down.
  7. Roku 3 Remote Control Motherboard Replacement: adım 7, 1 resimden 1.
    • Set aside the half of the remote with the buttons.
    • Take the the other half of the remote with one hand and remove the motherboard with your thumb and forefinger of the other hand.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Isobelle Espiritu
591 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-2, Livingston Fall 2016 Cal Poly, Team 15-2, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G2
3 Üyeler
6 adet Kılavuz yazıldı
4Kılavuz Yorumları
Thanks for the tutorial. Any idea where I can buy the motherboard for the Roku 3 remote?
Bret Dennis - Yanıt
Where can I buy a Roku 3 remote motherboard replacement?
A. J. Sitarsky - Yanıt
Hi, wondered if you had any luck locating a motherboard for the Roku 3? Thanks!
Paul Cacioppo -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 40
Her zaman: 5,345
