Ana içeriğe geç
Roku 4 Remote Control Motherboard Replacement
Neye ihtiyacın var
  1. Roku 4 Remote Control Motherboard Replacement, Remote Control Motherboard: adım 1, 1 resimden 1.
    • Place the remote control facing down on the table, so that the buttons are facing downwards.
  2. Roku 4 Remote Control Motherboard Replacement: adım 2, 2 resimden 1. Roku 4 Remote Control Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the battery compartment cover from the back of the remote by sliding it outwards. This should reveal the batteries.
  3. Roku 4 Remote Control Motherboard Replacement: adım 3, 2 resimden 1. Roku 4 Remote Control Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the batteries from the battery compartment.
  4. Roku 4 Remote Control Motherboard Replacement: adım 4, 1 resimden 1.
    • Turn the Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both battery compartments .
  5. Roku 4 Remote Control Motherboard Replacement: adım 5, 1 resimden 1.
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
    • Prying open the remote is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
    • Once you have created a gap large enough for your fingers to fit between, separate the top cover from the bottom plastic casing by pulling them apart gently.
  6. Roku 4 Remote Control Motherboard Replacement: adım 6, 3 resimden 1. Roku 4 Remote Control Motherboard Replacement: adım 6, 3 resimden 2. Roku 4 Remote Control Motherboard Replacement: adım 6, 3 resimden 3.
    • Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hank Harrison
467 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team S5-G4, Williams Spring 2017 Baylor, Team S5-G4, Williams Spring 2017 üyesi
BU-WILLIAMS-S17S5G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,674
