Ana içeriğe geç
Roku N1000 Motherboard Replacement
Neye ihtiyacın var
  1. Roku N1000 Motherboard Replacement, Remove Bottom Screws: adım 1, 2 resimden 1. Roku N1000 Motherboard Replacement, Remove Bottom Screws: adım 1, 2 resimden 2.
    • Remove the Philips head screws on the bottom side if the Roku box.
  2. Roku N1000 Motherboard Replacement, Bottom Half of Case: adım 2, 1 resimden 1.
    • Starting from the back of the box, begin to remove the the bottom of the Roku box using the prying tool.
    • Inside the Roku box on the bottom portion of the case, there are two tabs on both the left and right side.
    • Carefully pop the tabs out and lift the side with the prying tool.
  3. Roku N1000 Motherboard Replacement, Removing the Motherboard: adım 3, 2 resimden 1. Roku N1000 Motherboard Replacement, Removing the Motherboard: adım 3, 2 resimden 2.
    • Remove the two Philips screws on the motherboard and the screw on the back panel of the Roku box.
    • Carefully lift the Motherboard out of the Roku box.
Sonuç
Ryan Foley
101 İtibar
1 Kılavuz yazıldı
Ekip
Montana Tech, Team 1-5, Shirk Fall 2014 Montana Tech, Team 1-5, Shirk Fall 2014 üyesi
MTUM-SHIRK-F14S1G5
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 758
