Ana içeriğe geç
Roku Streaming Stick Motherboard Port replacement
Neye ihtiyacın var
  1. Roku Streaming Stick Motherboard Port replacement, Roku Streaming Stick Motherboard Port: adım 1, 1 resimden 1.
    • Grab the blue plastic opening tool to open the Roku Streaming Stick 3500R.
  2. Roku Streaming Stick Motherboard Port replacement: adım 2, 2 resimden 1. Roku Streaming Stick Motherboard Port replacement: adım 2, 2 resimden 2.
    • Place the blue plastic opening tool into one of the cracks on the back of the Roku to pop open the Roku Streaming Stick 3500R. Be careful not to break anything while removing the back.
  3. Roku Streaming Stick Motherboard Port replacement: adım 3, 1 resimden 1.
    • Once you have removed the cover, you can now access the motherboard of the Roku Streaming Stick.
  4. Roku Streaming Stick Motherboard Port replacement: adım 4, 2 resimden 1. Roku Streaming Stick Motherboard Port replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the motherboard by grabbing a hold of the micro-usb port, or you can also use tweezers to grab a hold of it and pull it out. But be careful with where you grab the motherboard.
  5. Roku Streaming Stick Motherboard Port replacement: adım 5, 3 resimden 1. Roku Streaming Stick Motherboard Port replacement: adım 5, 3 resimden 2. Roku Streaming Stick Motherboard Port replacement: adım 5, 3 resimden 3.
    • Once you identify the HDMI port and the micro-usb port, you can investigate to see which port may be damaged.
  6. Roku Streaming Stick Motherboard Port replacement: adım 6, 2 resimden 1. Roku Streaming Stick Motherboard Port replacement: adım 6, 2 resimden 2.
    • Once you have identified the problem you can then desolder the points at the HDMI as highlighted, or at the micro-usb ports.
    • If the soldering gun, or iron is set too high you then run the risk of destroying the motherboard altogether, or even damaging the wireless antennas.
Sonuç
If the replacement of the motherboard does not work, another part may need to be replaced.
For reassembly, follow instructions in reverse order.
4 farklı kişi bu kılavuzu tamamladı.
Andy Miller
203 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Wilson Spring 2018 IUPUI, Team S2-G2, Wilson Spring 2018 üyesi
IUPUI-WILSON-S18S2G2
4 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
Any idea where to buy a new hdmi port to solder on?
exxonchavez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 3,835
