Ana içeriğe geç
Roland G-800 Power Board Replacement
Neye ihtiyacın var
  1. Roland G-800 Power Board Replacement, Top cover: adım 1, 1 resimden 1.
    • Turn the keyboard upside down to access the screws
    • Remove 15 Philips PH2 screws
    • Don't worry about the other 16 screws, they hold the keys to the bottom case.
  2. Roland G-800 Power Board Replacement: adım 2, 2 resimden 1. Roland G-800 Power Board Replacement: adım 2, 2 resimden 2.
    • Turn the keyboard upright again and lift the top cover from the front
    • Remove 6 connectors
  3. Roland G-800 Power Board Replacement, Power Board: adım 3, 2 resimden 1. Roland G-800 Power Board Replacement, Power Board: adım 3, 2 resimden 2.
    • Remove the power output connector
    • Take note of the order of the wires here. In this case we have the white (neutral) wire on the left, but always double check when working with mains wiring.
    • Loosen the two flathead screws holding the mains wires to release them
  4. Roland G-800 Power Board Replacement: adım 4, 1 resimden 1.
    • Remove 4 PH2 screws holding the board to the case.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Andrew
1.341 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,977
