Ana içeriğe geç
Roller Blade Washer Replacement
Neye ihtiyacın var
  1. Roller Blade Washer Replacement, Washer: adım 1, 1 resimden 1.
    • The roller blade needs to be side down on a flat surface
  2. Roller Blade Washer Replacement: adım 2, 1 resimden 1.
    • Use an Allen Wrench to unscrew the screws on each side of the wheel.
  3. Roller Blade Washer Replacement: adım 3, 1 resimden 1.
    • Remove the screws and wheel from the blade.
  4. Roller Blade Washer Replacement: adım 4, 1 resimden 1.
    • Take the old plastic washer off the long screw.
  5. Roller Blade Washer Replacement: adım 5, 1 resimden 1.
    • Retrieve the new plastic washer and insert between the blades on the inner side. Do the same to the other side, so that both sides have new plastic washers
  6. Roller Blade Washer Replacement: adım 6, 1 resimden 1.
    • Replace the wheel without dislodging the new plastic washers and center the hole of the wheel in each plastic washer.
  7. Roller Blade Washer Replacement: adım 7, 1 resimden 1.
    • Reinsert the screws through the plastic washers and wheel.
  8. Roller Blade Washer Replacement: adım 8, 1 resimden 1.
    • Lastly, tighten the screws with the Allen Wrench.
Sonuç
You just finished replacing the plastic washers, you can now go out and skate to your hearts content
Bir başkası bu kılavuzu tamamladı.
Humza Khan
125 İtibar
1 Kılavuz yazıldı
Ekip
3Kılavuz Yorumları
ভিঢা বাজার অগ্রণী ব্যাংকের
হাসিবুর রহমান - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 2,698
