Ana içeriğe geç
Roller Derby Skate Toe Stop Replacement
Neye ihtiyacın var
  1. Roller Derby Skate Toe Stop Replacement, Toe Stop: adım 1, 2 resimden 1. Roller Derby Skate Toe Stop Replacement, Toe Stop: adım 1, 2 resimden 2.
    • Place the roller skate so the heel is touching the table and the toe is pointing up.
  2. Roller Derby Skate Toe Stop Replacement: adım 2, 2 resimden 1. Roller Derby Skate Toe Stop Replacement: adım 2, 2 resimden 2.
    • Loosen the nut with the wrench.
  3. Roller Derby Skate Toe Stop Replacement: adım 3, 3 resimden 1. Roller Derby Skate Toe Stop Replacement: adım 3, 3 resimden 2. Roller Derby Skate Toe Stop Replacement: adım 3, 3 resimden 3.
    • Twist the toe stop off with your hand.
  4. Roller Derby Skate Toe Stop Replacement: adım 4, 3 resimden 1. Roller Derby Skate Toe Stop Replacement: adım 4, 3 resimden 2. Roller Derby Skate Toe Stop Replacement: adım 4, 3 resimden 3.
    • Twist and remove the washer, split lock washer, and nut with your hand.
  5. Roller Derby Skate Toe Stop Replacement: adım 5, 3 resimden 1. Roller Derby Skate Toe Stop Replacement: adım 5, 3 resimden 2. Roller Derby Skate Toe Stop Replacement: adım 5, 3 resimden 3.
    • Place the nut, split lock washer, and washer on your new toe stop.
  6. Roller Derby Skate Toe Stop Replacement: adım 6, 1 resimden 1.
    • Align the thread of the toe stop screw with the thread on the skate.
    • The threads on the bolt are a soft metal and can bend, chip or break if you force the thread when screwing the toe stop back on.
  7. Roller Derby Skate Toe Stop Replacement: adım 7, 1 resimden 1.
    • Twist the toe stop back on with your hand.
  8. Roller Derby Skate Toe Stop Replacement: adım 8, 3 resimden 1. Roller Derby Skate Toe Stop Replacement: adım 8, 3 resimden 2. Roller Derby Skate Toe Stop Replacement: adım 8, 3 resimden 3.
    • Tighten the nut with the wrench to secure the toe stop in place.
    • Do not over tighten the nut as this can damage the threads on the toe stop or the skate.
    • You will know it's tight enough when you can no longer twist the toe stop off with your hand.
Sonuç
Repeat these steps for each roller skate you wish to replace the toe stop on.
Fabrizio Lopez
157 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,196
