Ana içeriğe geç
Roller Skate Double Action Cushion Replacement
Neye ihtiyacın var
  1. Roller Skate Double Action Cushion Replacement, Sure-Grip Double Action Cushion: adım 1, 1 resimden 1.
    • Using a 14 mm wrench, loosen and extract the bolt from the base plate.
  2. Roller Skate Double Action Cushion Replacement: adım 2, 1 resimden 1.
    • Once the bolt is no longer in the base plate, lift and twist the entire truck assembly from the skate.
  3. Roller Skate Double Action Cushion Replacement: adım 3, 2 resimden 1. Roller Skate Double Action Cushion Replacement: adım 3, 2 resimden 2.
    • Flip the truck over and remove the nut from the truck assembly bolt.
  4. Roller Skate Double Action Cushion Replacement: adım 4, 2 resimden 1. Roller Skate Double Action Cushion Replacement: adım 4, 2 resimden 2.
    • Remove both sets of cushions and retaining washers from the bolt.
  5. Roller Skate Double Action Cushion Replacement: adım 5, 3 resimden 1. Roller Skate Double Action Cushion Replacement: adım 5, 3 resimden 2. Roller Skate Double Action Cushion Replacement: adım 5, 3 resimden 3.
    • Remove the retaining washer from each cushion.
    • Use a spudger if the washer and cushion are difficult to separate.
    • Replace worn cushions and washers.
Sonuç
Jen Rushing
1 İtibar
1 Kılavuz yazıldı
Ekip
CCNTH Repair Project CCNTH Repair Project üyesi
Community
2 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 2,092
