Ana içeriğe geç
Roof Shingle Replacement
Neye ihtiyacın var
  1. Roof Shingle Replacement, Roof shingle: adım 1, 1 resimden 1.
    • Remove the broken shingle by lifting the nails with the claw side of a hammer.
    • Use caution when handling a hammer and nails.
  2. Roof Shingle Replacement: adım 2, 1 resimden 1.
    • Remove the single broken shingle, carefully, without ripping out the shingles above.
  3. Roof Shingle Replacement: adım 3, 1 resimden 1.
    • Remove the adhesion strip off of the new shingle.
  4. Roof Shingle Replacement: adım 4, 1 resimden 1.
    • Slip the new shingle in place, and line it up where the old shingle previously was.
  5. Roof Shingle Replacement: adım 5, 2 resimden 1. Roof Shingle Replacement: adım 5, 2 resimden 2.
    • Secure the shingle with three 7/8" roofing nails.
    • Be careful when hammering in the nails.
  6. Roof Shingle Replacement: adım 6, 1 resimden 1.
    • Slightly lift the edges of the shingle and apply a thin layer of cement along it.
  7. Roof Shingle Replacement: adım 7, 1 resimden 1.
    • Press down the edges to lock the shingle in place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
Great post! Roof repair is something you should only really do as a quick patch though. If one of your shingles has fallen off, odds are a lot more of them are going to be falling off soon too. You need to find the Best Quality shingles just to make sure that they stay on as long as your other ones.
Best Quality - Yanıt
Yeah those 3 in 1s are definitely NOT good quality, they are old and soon to be extinct. (Good riddance)
OOtysweat97 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 68
Her zaman: 1,130
