Ana içeriğe geç
Rosewill NEON M62 Cable Replacement
Neye ihtiyacın var
  1. Rosewill NEON M62 Cable Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Cable Replacement: adım 2, 1 resimden 1.
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Cable Replacement: adım 3, 2 resimden 1. Rosewill NEON M62 Cable Replacement: adım 3, 2 resimden 2.
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Cable Replacement, Cable: adım 4, 2 resimden 1. Rosewill NEON M62 Cable Replacement, Cable: adım 4, 2 resimden 2.
    • Gently pull the cable toward yourself and around the right side, being careful not to damage the wires.
  5. Rosewill NEON M62 Cable Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Carefully, using your fingers or tweezers, pull the white connecter up.
    • Do not pull by the wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Julian Abraham
414 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 üyesi
UMASSD-RYCKEBUSCH-S23S7G2
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 70
