Ana içeriğe geç
Rosewill NEON M62 Sensor Cover Replacement
Neye ihtiyacın var
  1. Rosewill NEON M62 Sensor Cover Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Sensor Cover Replacement: adım 2, 1 resimden 1.
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Sensor Cover Replacement: adım 3, 2 resimden 1. Rosewill NEON M62 Sensor Cover Replacement: adım 3, 2 resimden 2.
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Sensor Cover Replacement, Sensor Cover: adım 4, 1 resimden 1.
    • Remove the four 5 mm screws with a Philips #00 screwdriver.
  5. Rosewill NEON M62 Sensor Cover Replacement: adım 5, 2 resimden 1. Rosewill NEON M62 Sensor Cover Replacement: adım 5, 2 resimden 2.
    • Remove the center clear plastic piece, known as the sensor cover.
Sonuç
Sean Turk
217 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 üyesi
UMASSD-RYCKEBUSCH-S23S7G2
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 62
