Ana içeriğe geç
Rotary Multi Selector Wheel Removal
Neye ihtiyacın var
  1. Rotary Multi Selector Wheel Removal, Back Cover Removal: adım 1, 3 resimden 1. Rotary Multi Selector Wheel Removal, Back Cover Removal: adım 1, 3 resimden 2. Rotary Multi Selector Wheel Removal, Back Cover Removal: adım 1, 3 resimden 3.
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  2. Rotary Multi Selector Wheel Removal: adım 2, 1 resimden 1.
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  3. Rotary Multi Selector Wheel Removal, Detaching Ribbon: adım 3, 2 resimden 1. Rotary Multi Selector Wheel Removal, Detaching Ribbon: adım 3, 2 resimden 2.
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  4. Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: adım 4, 3 resimden 1. Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: adım 4, 3 resimden 2. Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: adım 4, 3 resimden 3.
    • Lift up the metal cover and its button slowly using the tweezers.
Sonuç
Andrew Lau
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 8-56, Johann Spring 2013 Cal Poly, Team 8-56, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S8G56
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 15
Her zaman: 514
