Ana içeriğe geç
Rowenta Focus Heating Element and Soleplate Replacement
Neye ihtiyacın var
    1. Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: adım 1, 2 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: adım 1, 2 resimden 2.
      • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
      • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
      FixBot'a Sor
      Yorum Ekle
    2. Rowenta Focus Heating Element and Soleplate Replacement: adım 2, 3 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement: adım 2, 3 resimden 2. Rowenta Focus Heating Element and Soleplate Replacement: adım 2, 3 resimden 3.
      • Pry the back cover of the iron off using a metal spudger.
      • Remove the back cover, exposing the wiring in the iron.
      FixBot'a Sor
      Yorum Ekle
    3. Rowenta Focus Heating Element and Soleplate Replacement: adım 3, 2 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement: adım 3, 2 resimden 2.
      • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
      • Leave the other cords attached to the main cord.
      FixBot'a Sor
      Yorum Ekle
    4. Rowenta Focus Heating Element and Soleplate Replacement: adım 4, 2 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement: adım 4, 2 resimden 2.
      • Pull out the motherboard inside handle of iron.
      • Keep it attached to main power cord and other components.
      FixBot'a Sor
      Yorum Ekle
    5. Rowenta Focus Heating Element and Soleplate Replacement: adım 5, 3 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement: adım 5, 3 resimden 2. Rowenta Focus Heating Element and Soleplate Replacement: adım 5, 3 resimden 3.
      • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
      FixBot'a Sor
      Yorum Ekle
    1. Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: adım 6, 3 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: adım 6, 3 resimden 2. Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: adım 6, 3 resimden 3.
      • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
      • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
      • Lift out the piece.
      FixBot'a Sor
      Yorum Ekle
    2. Rowenta Focus Heating Element and Soleplate Replacement: adım 7, 3 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement: adım 7, 3 resimden 2. Rowenta Focus Heating Element and Soleplate Replacement: adım 7, 3 resimden 3.
      • Replace with an identical part by inserting it into the space.
      FixBot'a Sor
      Yorum Ekle
    1. Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: adım 8, 2 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: adım 8, 2 resimden 2.
      • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
      FixBot'a Sor
      Yorum Ekle
    2. Rowenta Focus Heating Element and Soleplate Replacement: adım 9, 2 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement: adım 9, 2 resimden 2.
      • Unhook the clips on the top of the metal piece.
      • Using the metal spudger, remove the metal piece on the tip of the iron.
      FixBot'a Sor
      Yorum Ekle
    3. Rowenta Focus Heating Element and Soleplate Replacement: adım 10, 2 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement: adım 10, 2 resimden 2.
      • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
      FixBot'a Sor
      Yorum Ekle
    4. Rowenta Focus Heating Element and Soleplate Replacement: adım 11, 3 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement: adım 11, 3 resimden 2. Rowenta Focus Heating Element and Soleplate Replacement: adım 11, 3 resimden 3.
      • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
      FixBot'a Sor
      Yorum Ekle
    5. Rowenta Focus Heating Element and Soleplate Replacement: adım 12, 3 resimden 1. Rowenta Focus Heating Element and Soleplate Replacement: adım 12, 3 resimden 2. Rowenta Focus Heating Element and Soleplate Replacement: adım 12, 3 resimden 3.
      • Lift the iron up using the handle to completely detach the soleplate.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Bella Navarro
462 İtibar
3 adet Kılavuz yazıldı
1Rehber Yorum
hi how do i clean sole plate inside ??????????????????? wath sort of sealent do they use to seal it or where do you get it from????????????????
Willie Waldner - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 51
Son 30 gün: 200
Her zaman: 7,091
