Ana içeriğe geç
Rowenta Focus Material Setting Knob Replacement
Neye ihtiyacın var
  1. Rowenta Focus Material Setting Knob Replacement, Power Assembly: adım 1, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement, Power Assembly: adım 1, 2 resimden 2.
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
    FixBot'a Sor
    Yorum Ekle
  2. Rowenta Focus Material Setting Knob Replacement: adım 2, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 2, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement: adım 2, 3 resimden 3.
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
    FixBot'a Sor
    Yorum Ekle
  3. Rowenta Focus Material Setting Knob Replacement: adım 3, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 3, 2 resimden 2.
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
    FixBot'a Sor
    Yorum Ekle
  4. Rowenta Focus Material Setting Knob Replacement: adım 4, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 4, 2 resimden 2.
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
    FixBot'a Sor
    Yorum Ekle
  5. Rowenta Focus Material Setting Knob Replacement: adım 5, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 5, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement: adım 5, 3 resimden 3.
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
    FixBot'a Sor
    Yorum Ekle
  6. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: adım 6, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: adım 6, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: adım 6, 3 resimden 3.
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
    FixBot'a Sor
    Yorum Ekle
  7. Rowenta Focus Material Setting Knob Replacement: adım 7, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 7, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement: adım 7, 3 resimden 3.
    • Replace with an identical part by inserting it into the space.
    FixBot'a Sor
    Yorum Ekle
  8. Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: adım 8, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: adım 8, 2 resimden 2.
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
    FixBot'a Sor
    Yorum Ekle
  9. Rowenta Focus Material Setting Knob Replacement: adım 9, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 9, 2 resimden 2.
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
    FixBot'a Sor
    Yorum Ekle
  10. Rowenta Focus Material Setting Knob Replacement: adım 10, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 10, 2 resimden 2.
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
    FixBot'a Sor
    Yorum Ekle
  11. Rowenta Focus Material Setting Knob Replacement: adım 11, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 11, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement: adım 11, 3 resimden 3.
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
    FixBot'a Sor
    Yorum Ekle
  12. Rowenta Focus Material Setting Knob Replacement: adım 12, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 12, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement: adım 12, 3 resimden 3.
    • Lift the iron up using the handle to completely detach the soleplate.
    FixBot'a Sor
    Yorum Ekle
  13. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: adım 13, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: adım 13, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: adım 13, 3 resimden 3.
    • Using the T20 screwdriver, remove both of the 20mm screws on the underside of the iron.
    FixBot'a Sor
    Yorum Ekle
  14. Rowenta Focus Material Setting Knob Replacement: adım 14, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 14, 2 resimden 2.
    • Turn the iron over and pull the knob off.
    • Be careful not to tip the iron after removing the knob; there are small springs in the white piece underneath the knob.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bella Navarro
462 İtibar
3 adet Kılavuz yazıldı
1Rehber Yorum
Nice pics, came apart easily with this guide. Just need a note on the small ball bearing which I assume goes somewhere on the steam valve?
Step - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 80
Her zaman: 2,309
