Ana içeriğe geç
Rowenta Focus Material Setting Knob Replacement
Neye ihtiyacın var
  1. Rowenta Focus Material Setting Knob Replacement, Power Assembly: adım 1, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement, Power Assembly: adım 1, 2 resimden 2.
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
  2. Rowenta Focus Material Setting Knob Replacement: adım 2, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 2, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement: adım 2, 3 resimden 3.
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
  3. Rowenta Focus Material Setting Knob Replacement: adım 3, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 3, 2 resimden 2.
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
  4. Rowenta Focus Material Setting Knob Replacement: adım 4, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 4, 2 resimden 2.
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
  5. Rowenta Focus Material Setting Knob Replacement: adım 5, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 5, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement: adım 5, 3 resimden 3.
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
  6. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: adım 6, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: adım 6, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: adım 6, 3 resimden 3.
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
  7. Rowenta Focus Material Setting Knob Replacement: adım 7, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 7, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement: adım 7, 3 resimden 3.
    • Replace with an identical part by inserting it into the space.
  8. Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: adım 8, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: adım 8, 2 resimden 2.
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
  9. Rowenta Focus Material Setting Knob Replacement: adım 9, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 9, 2 resimden 2.
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
  10. Rowenta Focus Material Setting Knob Replacement: adım 10, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 10, 2 resimden 2.
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
  11. Rowenta Focus Material Setting Knob Replacement: adım 11, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 11, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement: adım 11, 3 resimden 3.
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
  12. Rowenta Focus Material Setting Knob Replacement: adım 12, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 12, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement: adım 12, 3 resimden 3.
    • Lift the iron up using the handle to completely detach the soleplate.
  13. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: adım 13, 3 resimden 1. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: adım 13, 3 resimden 2. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: adım 13, 3 resimden 3.
    • Using the T20 screwdriver, remove both of the 20mm screws on the underside of the iron.
  14. Rowenta Focus Material Setting Knob Replacement: adım 14, 2 resimden 1. Rowenta Focus Material Setting Knob Replacement: adım 14, 2 resimden 2.
    • Turn the iron over and pull the knob off.
    • Be careful not to tip the iron after removing the knob; there are small springs in the white piece underneath the knob.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bella Navarro
426 İtibar
3 adet Kılavuz yazıldı
Bir Yorum
Nice pics, came apart easily with this guide. Just need a note on the small ball bearing which I assume goes somewhere on the steam valve?
Step - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 883
