Ana içeriğe geç
Rowenta Focus Power Assembly Replacement
Neye ihtiyacın var
  1. Rowenta Focus Power Assembly Replacement, Power Assembly: adım 1, 2 resimden 1. Rowenta Focus Power Assembly Replacement, Power Assembly: adım 1, 2 resimden 2.
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
    FixBot'a Sor
    Yorum Ekle
  2. Rowenta Focus Power Assembly Replacement: adım 2, 3 resimden 1. Rowenta Focus Power Assembly Replacement: adım 2, 3 resimden 2. Rowenta Focus Power Assembly Replacement: adım 2, 3 resimden 3.
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
    FixBot'a Sor
    Yorum Ekle
  3. Rowenta Focus Power Assembly Replacement: adım 3, 2 resimden 1. Rowenta Focus Power Assembly Replacement: adım 3, 2 resimden 2.
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
    FixBot'a Sor
    Yorum Ekle
  4. Rowenta Focus Power Assembly Replacement: adım 4, 2 resimden 1. Rowenta Focus Power Assembly Replacement: adım 4, 2 resimden 2.
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
    FixBot'a Sor
    Yorum Ekle
  5. Rowenta Focus Power Assembly Replacement: adım 5, 3 resimden 1. Rowenta Focus Power Assembly Replacement: adım 5, 3 resimden 2. Rowenta Focus Power Assembly Replacement: adım 5, 3 resimden 3.
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device with new power supply, follow these instructions in reverse order.
4 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Thanks... Where we can get parts
Baiju Vasavan - Yanıt Paylaş
Tengo un Rowenta de la que se recoge el cable pero no veo los tornillos por donde destaparla
Jose Rojas - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 19
Son 30 gün: 165
Her zaman: 8,434
