Ana içeriğe geç
Royal Enfield:How to Clean Final Drive Chain
  1. Royal Enfield:How to Clean Final Drive Chain, Things Required: adım 1, 3 resimden 1. Royal Enfield:How to Clean Final Drive Chain, Things Required: adım 1, 3 resimden 2. Royal Enfield:How to Clean Final Drive Chain, Things Required: adım 1, 3 resimden 3.
    • Things required:
    • 1. A bottle of 500 ml diesel or any low solvent oil, like kerosene 2. A used toothbrush 3. A can 4. Clean cotton cloth. 5 Motul Chain lube C-2 6. Hand wrench no.10
  2. Royal Enfield:How to Clean Final Drive Chain, Cleaning The Chain: adım 2, 3 resimden 1. Royal Enfield:How to Clean Final Drive Chain, Cleaning The Chain: adım 2, 3 resimden 2. Royal Enfield:How to Clean Final Drive Chain, Cleaning The Chain: adım 2, 3 resimden 3.
    • 1. Keep the motorcycle in centre stand. 2. Unscrew the two screws of Chain Cover and remove the cover. 3. Pour some quantity of diesel to a clean container. 4. Dip the toothbrush in diesel. 5. Start brushing the rollers and both sides of the chain thoroughly while rotating the rear tyre slowly. 6. Once done wipe the chain with the cotton cloth.
  3. Royal Enfield:How to Clean Final Drive Chain, Lubing the Chain: adım 3, 2 resimden 1. Royal Enfield:How to Clean Final Drive Chain, Lubing the Chain: adım 3, 2 resimden 2.
    • 7. Now spray the Motul Chain lube C-2 from a close distance while rotating the rear tyre slowly. 8. Wait for 10 minutes. 9. Put the Chain Cover in appropriate position and tight the screws.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
soumitra sengupta
532 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
Two points, why Diesel SHOUDN'T be used! First: The Diesel will attack the seals between the rings of the chain, wich prevent the lifetime grease filling to come out (same thing with Kerosine, Petroleum, Gasoline and high concentrations of any alcohol). If the Grease filling already came out, the chain is still useable, but it will wear out very fast. Second point is that the Diesel (which is pretty toxic and harmful to animals and humans) goes on the street and the next rain will take it in the nature. So DON'T use it! Don't wanna make advertisement, but I'm using the products from GreenOil, wich are 100% plant based and completely Biodegradable (http://www.green-oil.net). If you don't wanna take this, use something wich is declared as a special motorcycle chain cleaning product and compatible with O-,X-,W-Chains (probably Motul has one of these in their programs).
Leonard Kesting - Yanıt
Good وممتاز
Hada - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 40
Son 30 gün: 177
Her zaman: 9,783
