Giriş
The thermostat regulates temperature, if you change the temperature, using the dial, and the heater is not responding then you need to replace the thermostat.
Neye ihtiyacın var
Flip the device over so the bottom is facing up.
Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
Remove the two 10 mm Phillips screws using a #2 Phillips screw driver. One attaches the gold metal bracket to the heater coil housing and the other attaches the fuse holder to heater coil housing.
Pull off the black thermostat extension by pulling up. This should require very little force and should come apart easily.
