Ana içeriğe geç
Royal Kludge GK64 Keyboard Switch Spring Replacement
Neye ihtiyacın var
  1. Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: adım 1, 2 resimden 1. Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: adım 1, 2 resimden 2.
    • Use a keycap remover to pull your keycap up and off of the keyboard.
    • Remove any keycaps surrounding the one you are working on if you need more space.
  2. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 2, 3 resimden 1. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 2, 3 resimden 2. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 2, 3 resimden 3.
    • Use the switch puller to pull the desired switch out of your keyboard.
  3. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 3, 2 resimden 1. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 3, 2 resimden 2.
    • Place your switch onto your switch opener, and gently push down.
    • Make sure the switch is securely in place and continue to remove the top housing.
  4. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 4, 3 resimden 1. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 4, 3 resimden 2. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 4, 3 resimden 3.
    • Use the stem holder to remove the stem, which will reveal the switch spring.
    • Remove the switch spring.
  5. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 5, 2 resimden 1. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 5, 2 resimden 2.
    • Align your new spring with the center of the bottom housing and gently place the switch spring.
  6. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 6, 3 resimden 1. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 6, 3 resimden 2. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 6, 3 resimden 3.
    • To put the stem back, align the stem legs with the metal plate on the switch.
    • Remove the switch from the switch opener.
    • Gently push down onto the housing until you hear a click and both pieces are into place.
  7. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 7, 2 resimden 1. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 7, 2 resimden 2.
    • Align the pins located at the bottom of the switch to the corresponding pin holes in the keyboard.
    • Gently push the switch back into the keyboard.
  8. Royal Kludge GK64 Keyboard Switch Spring Replacement: adım 8, 1 resimden 1.
    • Place the keycap back onto the switch and push down to secure the keycap.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Diksha Sakre
228 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 604
