Ana içeriğe geç
Royal Sovereign Fan Replacement
Neye ihtiyacın var
  1. Royal Sovereign Fan Replacement, Fan: adım 1, 2 resimden 1. Royal Sovereign Fan Replacement, Fan: adım 1, 2 resimden 2.
    • Make sure that the heater is unplugged and completely cooled down.
    • Turn the heater so the back is facing up.
    • Remove all six 14 mm screws using the Philips #0 screwdriver.
  2. Royal Sovereign Fan Replacement: adım 2, 1 resimden 1.
    • Separate the back case from the heater.
  3. Royal Sovereign Fan Replacement: adım 3, 2 resimden 1. Royal Sovereign Fan Replacement: adım 3, 2 resimden 2.
    • You are left with the motor and wires attached to the front case.
    • Use the Phillips #1 screwdriver to remove the four 14 mm screws attaching the motor to the front case..
    • Do not untangle the wires
  4. Royal Sovereign Fan Replacement: adım 4, 2 resimden 1. Royal Sovereign Fan Replacement: adım 4, 2 resimden 2.
    • Turn the motor over to reveal the fan.
    • Use a plier to twist and unscrew the hexagonal screw attached to the fan.
  5. Royal Sovereign Fan Replacement: adım 5, 1 resimden 1.
    • Take the fan out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 343
