Ana içeriğe geç
Rozia HQ242 Trimmer Spring Replacement
Neye ihtiyacın var
  1. Rozia HQ242 Trimmer Spring Replacement, Spring: adım 1, 3 resimden 1. Rozia HQ242 Trimmer Spring Replacement, Spring: adım 1, 3 resimden 2. Rozia HQ242 Trimmer Spring Replacement, Spring: adım 1, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the two 6 mm screws securing the blade to the trimmer.
  2. Rozia HQ242 Trimmer Spring Replacement: adım 2, 2 resimden 1. Rozia HQ242 Trimmer Spring Replacement: adım 2, 2 resimden 2.
    • Gently lift the inner blade straight up and away from the device.
    • With the blades removed, now is a good time to clean the trimmer using a small brush, dust blower, or q-tips.
  3. Rozia HQ242 Trimmer Spring Replacement: adım 3, 3 resimden 1. Rozia HQ242 Trimmer Spring Replacement: adım 3, 3 resimden 2. Rozia HQ242 Trimmer Spring Replacement: adım 3, 3 resimden 3.
    • Gently lift the spring away from the trimmer.
    • You may need to point the legs of the spring at a 45-degree angle before you can pull it out.
    • Take note of the shape of the spring. There is a flat U-shaped bend that rests on a notch in the trimmer. This information will be important when putting everything back together!
  4. Rozia HQ242 Trimmer Spring Replacement: adım 4, 3 resimden 1. Rozia HQ242 Trimmer Spring Replacement: adım 4, 3 resimden 2. Rozia HQ242 Trimmer Spring Replacement: adım 4, 3 resimden 3.
    • Align the flat U-shaped end of the spring to the notch on the trimmer.
    • Gently pinch the two legs of the spring with your thumb and index finger, aligning them to point towards the front of the trimmer at a 45-degree angle, then drop it into the slot.
    • Once it is successfully in, carefully let go. If it falls off the notch, you will have to wedge it out and try again. This may take multiple attempts.
    • Make sure that the spring is securely resting on the notch, or the trimmer may not function properly!
  5. Rozia HQ242 Trimmer Spring Replacement: adım 5, 3 resimden 1. Rozia HQ242 Trimmer Spring Replacement: adım 5, 3 resimden 2. Rozia HQ242 Trimmer Spring Replacement: adım 5, 3 resimden 3.
    • Reinstall the inner blade.
    • The notch located on the back of the blade must align with the gold-plated contact.
    • Gently push down so that the plate rests against the front of the trimmer.
    • Take extra caution not to dislodge the spring from its position, especially after pressing down on the blade.
  6. Rozia HQ242 Trimmer Spring Replacement: adım 6, 3 resimden 1. Rozia HQ242 Trimmer Spring Replacement: adım 6, 3 resimden 2. Rozia HQ242 Trimmer Spring Replacement: adım 6, 3 resimden 3.
    • Carefully reattach the outer blade.
    • The screw holes protrude just enough to allow the blade to 'click' into position.
    • Use a Phillips #1 screwdriver to replace the two 6 mm screws that secure the outer blade.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jose Lucio
201 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 8-3, Grodsky Spring 2024 CSU Los Angeles, Team 8-3, Grodsky Spring 2024 üyesi
CSULA-GRODSKY-S24S8G3
2 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 20
Son 30 gün: 72
Her zaman: 646
