Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Gently pull the top of the watch's back until the cap detaches, in a peeling motion.
Pull out the white cap and green chip once it is free.
Carefully puncture the plastic casing next to the battery on top of the green chip with the X-Acto knife and stop.
Flip the chip around to the front.
In a chiseling motion, make an incision on the front side above the battery to cut out a plastic casing.
Remove the cut plastic casing over the battery.
Gently remove the battery with a spudger or a wooden coffee stick.
Once free, remove the dead battery.
Insert the new battery.
Place the cut plastic cap casing over the chip and battery.
Place the white cap over the green chip.
Insert the white cap and green chip into the back of the watch with the spudger or wooden coffee stick.
Turn over the watch and check the power.
