Ana içeriğe geç
Ryobi D620H Mode Selector Switch Replacement
Neye ihtiyacın var
  1. Ryobi D620H Mode Selector Switch Replacement, Right Side Case: adım 1, 1 resimden 1.
    • All nine 16mm long Torx20 screws (Circled in red).
    • Turn the screwdriver counterclockwise to loosen the screws.
    • Remove all nine screws completely.
    • Place in parts tray (Optional)
  2. Ryobi D620H Mode Selector Switch Replacement: adım 2, 2 resimden 1. Ryobi D620H Mode Selector Switch Replacement: adım 2, 2 resimden 2.
    • Pry the right side of the case off to expose the internal components.
  3. Ryobi D620H Mode Selector Switch Replacement, Mode Selector Switch: adım 3, 1 resimden 1.
    • The mode selector switch (Circled in red) once the right side case is removed.
    • Before disassembling, the mode shift button is visible on the top of the case.
  4. Ryobi D620H Mode Selector Switch Replacement: adım 4, 3 resimden 1. Ryobi D620H Mode Selector Switch Replacement: adım 4, 3 resimden 2. Ryobi D620H Mode Selector Switch Replacement: adım 4, 3 resimden 3.
    • Push the mode selector switch up (away from the work surface) to dislodge it.
    • Lift the mode selector switch out of its slot.
Sonuç
To reassemble your device, place the mode shift button in the slot it was removed from at a slight angle and straighten it out as you push it into place.
Congratulations, you have replaced the mode shift button on your Ryobi hammer drill!
Bir başkası bu kılavuzu tamamladı.
Jacob da Ponte
469 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Petersen Fall 2023 UMass Dartmouth, Team 1-2, Petersen Fall 2023 üyesi
UMASSD-PETERSEN-F23S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 88
