Ana içeriğe geç
Ryobi D620H Trigger Replacement
Neye ihtiyacın var
    1. Ryobi D620H Trigger Replacement, Right Side Case Removal: adım 1, 1 resimden 1.
      • Turn the drill so that the screws face upwards.
      • Use the Torx T20 screwdriver to remove all nine screws.
      FixBot'a Sor
      Yorum Ekle
    2. Ryobi D620H Trigger Replacement: adım 2, 2 resimden 1. Ryobi D620H Trigger Replacement: adım 2, 2 resimden 2.
      • Insert the end of an opening tool between the right and left sides of the drill to pry the right side of the case.
      • Remove the right side case to expose the inside of the drill.
      FixBot'a Sor
      Yorum Ekle
    1. Ryobi D620H Trigger Replacement, Power Cord: adım 3, 1 resimden 1.
      • The bend relief cover at the bottom of the handle.
      • Follow the wires coming out of the bend relief cover to the white power cord clamp with the two 14 mm black PH1 screws.
      FixBot'a Sor
      Yorum Ekle
    2. Ryobi D620H Trigger Replacement: adım 4, 2 resimden 1. Ryobi D620H Trigger Replacement: adım 4, 2 resimden 2.
      • Unscrew the two 14 mm PH1 screws holding the power cord wire in place.
      • Lift the switch box from its place gently.
      FixBot'a Sor
      Yorum Ekle
    3. Ryobi D620H Trigger Replacement: adım 5, 3 resimden 1. Ryobi D620H Trigger Replacement: adım 5, 3 resimden 2. Ryobi D620H Trigger Replacement: adım 5, 3 resimden 3.
      • Remove the two little screws holding the brass terminal lugs in place. Although it is not required, you can remove the screws completely if you find that doing so is more convenient.
      • Gently pull the white positive and black negative wires that are connected to the switch box.
      • Slide the bend relief guard off the cord towards the loose connections.
      FixBot'a Sor
      Yorum Ekle
    1. Ryobi D620H Trigger Replacement, Trigger: adım 6, 2 resimden 1. Ryobi D620H Trigger Replacement, Trigger: adım 6, 2 resimden 2.
      • Pull the four cables from the trigger terminals.
      FixBot'a Sor
      Yorum Ekle
    2. Ryobi D620H Trigger Replacement: adım 7, 1 resimden 1.
      • Pull the two black wires that connect the motor from the switch box.
      • This may require some force.
      • When replacing the switch box these connections push into the new switch box.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jacob da Ponte
469 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Petersen Fall 2023 UMass Dartmouth, Team 1-2, Petersen Fall 2023 üyesi
UMASSD-PETERSEN-F23S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 591
