Ana içeriğe geç
Ryobi P202 Level Gauge Replacement
Neye ihtiyacın var
  1. Ryobi P202 Level Gauge Replacement, Battery: adım 1, 3 resimden 1. Ryobi P202 Level Gauge Replacement, Battery: adım 1, 3 resimden 2. Ryobi P202 Level Gauge Replacement, Battery: adım 1, 3 resimden 3.
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi P202 Level Gauge Replacement, Right Side Case: adım 2, 2 resimden 1. Ryobi P202 Level Gauge Replacement, Right Side Case: adım 2, 2 resimden 2.
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
    FixBot'a Sor
    Yorum Ekle
  3. Ryobi P202 Level Gauge Replacement: adım 3, 2 resimden 1. Ryobi P202 Level Gauge Replacement: adım 3, 2 resimden 2.
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
    FixBot'a Sor
    Yorum Ekle
  4. Ryobi P202 Level Gauge Replacement, Level Gauge: adım 4, 3 resimden 1. Ryobi P202 Level Gauge Replacement, Level Gauge: adım 4, 3 resimden 2. Ryobi P202 Level Gauge Replacement, Level Gauge: adım 4, 3 resimden 3.
    • Rotate the Drill 180 degrees so that the top is facing you.
    • Lift the level gauge out from the top corner of the drill.
    • The level gauge is Part #: 3000909
    FixBot'a Sor
    Yorum Ekle
Sonuç
Joseph Eckstein
1.596 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G6
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 791
