Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide demonstrates how to replace the level gauge of the drill, located along the top of drill. The process requires opening the drill, but does not require removing any of the internal electronic components.
Parçalar
Hiçbir parça belirtilmedi.
  1. The battery can shock you.  Only touch plastic, non-conductive components. Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards. Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior. Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Gently lift the casing from the drill body. Take the casing completely off the drill body to gain access to the interior of the drill.
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  5. Rotate the Drill 180 degrees so that the top is facing you. Lift the level gauge out from the top corner of the drill. The level gauge is Part #: 3000909
    • Rotate the Drill 180 degrees so that the top is facing you.
    • Lift the level gauge out from the top corner of the drill.
    • The level gauge is Part #: 3000909
Sonuç
Joseph Eckstein
1.533 İtibar
9 adet Kılavuz yazıldı
Takım
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 245
