Ana içeriğe geç
Ryobi P202 Magnetic Tray Replacement
Neye ihtiyacın var
  1. Ryobi P202 Magnetic Tray Replacement, Battery: adım 1, 3 resimden 1. Ryobi P202 Magnetic Tray Replacement, Battery: adım 1, 3 resimden 2. Ryobi P202 Magnetic Tray Replacement, Battery: adım 1, 3 resimden 3.
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Magnetic Tray Replacement, Right Side Case: adım 2, 2 resimden 1. Ryobi P202 Magnetic Tray Replacement, Right Side Case: adım 2, 2 resimden 2.
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Magnetic Tray Replacement: adım 3, 2 resimden 1. Ryobi P202 Magnetic Tray Replacement: adım 3, 2 resimden 2.
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Magnetic Tray Replacement, Magnetic Tray: adım 4, 2 resimden 1. Ryobi P202 Magnetic Tray Replacement, Magnetic Tray: adım 4, 2 resimden 2.
    • Gently lift the magnetic tray from the bottom of the drill body.
    • The magnet is Part #: 303001015
Sonuç
Joseph Eckstein
1.596 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 370
