Ana içeriğe geç
Ryobi P202 Right Side Case Replacement
Neye ihtiyacın var
  1. Ryobi P202 Right Side Case Replacement, Battery: adım 1, 3 resimden 1. Ryobi P202 Right Side Case Replacement, Battery: adım 1, 3 resimden 2. Ryobi P202 Right Side Case Replacement, Battery: adım 1, 3 resimden 3.
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Right Side Case Replacement, Right Side Case: adım 2, 2 resimden 1. Ryobi P202 Right Side Case Replacement, Right Side Case: adım 2, 2 resimden 2.
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Right Side Case Replacement: adım 3, 2 resimden 1. Ryobi P202 Right Side Case Replacement: adım 3, 2 resimden 2.
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
Sonuç
Joseph Eckstein
1.596 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 753
