Ana içeriğe geç
Ryobi P202 Trigger Assembly Replacement
Neye ihtiyacın var
    1. Ryobi P202 Trigger Assembly Replacement, Battery: adım 1, 3 resimden 1. Ryobi P202 Trigger Assembly Replacement, Battery: adım 1, 3 resimden 2. Ryobi P202 Trigger Assembly Replacement, Battery: adım 1, 3 resimden 3.
      • The battery can shock you. Only touch plastic, non-conductive components.
      • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
      FixBot'a Sor
      Yorum Ekle
    1. Ryobi P202 Trigger Assembly Replacement, Right Side Case: adım 2, 2 resimden 1. Ryobi P202 Trigger Assembly Replacement, Right Side Case: adım 2, 2 resimden 2.
      • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
      FixBot'a Sor
      Yorum Ekle
    2. Ryobi P202 Trigger Assembly Replacement: adım 3, 2 resimden 1. Ryobi P202 Trigger Assembly Replacement: adım 3, 2 resimden 2.
      • Gently lift the casing from the drill body.
      • Take the casing completely off the drill body to gain access to the interior of the drill.
      • The Ryobi P202 casing has Part #: 200690001
      FixBot'a Sor
      Yorum Ekle
    1. Ryobi P202 Trigger Assembly Replacement, Battery Contacts: adım 4, 2 resimden 1. Ryobi P202 Trigger Assembly Replacement, Battery Contacts: adım 4, 2 resimden 2.
      • Grip the battery clip and pull straight up to remove the metal battery contacts.
      • You can now clean the metal battery contacts with isopropyl alcohol.
      FixBot'a Sor
      Yorum Ekle
    1. Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: adım 5, 2 resimden 1. Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: adım 5, 2 resimden 2.
      • Holding the direction select switch in place, grip both sides of the trigger assembly and lift it up and towards the base of the drill.
      FixBot'a Sor
      Yorum Ekle
    2. Ryobi P202 Trigger Assembly Replacement: adım 6, 2 resimden 1. Ryobi P202 Trigger Assembly Replacement: adım 6, 2 resimden 2.
      • To separate the trigger assembly from the motor, use a soldering iron to melt the solder and pull gently on the red and black wires from the trigger.
      • Heating the solder may melt the plastic packaging. Prior experience with soldering is required.
      • The trigger assembly is Part #: 270001392
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. You will need solder to reattach the wires to the trigger assembly.
Bir başkası bu kılavuzu tamamladı.
Joseph Eckstein
1.596 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G6
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 53
Her zaman: 5,746
