Ana içeriğe geç
Ryobi P235 Direction of Rotation Selector Replacement
Neye ihtiyacın var
  1. Ryobi P235 Direction of Rotation Selector Replacement, Battery: adım 1, 2 resimden 1. Ryobi P235 Direction of Rotation Selector Replacement, Battery: adım 1, 2 resimden 2.
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi P235 Direction of Rotation Selector Replacement: adım 2, 2 resimden 1. Ryobi P235 Direction of Rotation Selector Replacement: adım 2, 2 resimden 2.
    • Pull the battery away from the drill housing while holding in both tabs.
    FixBot'a Sor
    Yorum Ekle
  3. Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: adım 3, 2 resimden 1. Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: adım 3, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
    FixBot'a Sor
    Yorum Ekle
  4. Ryobi P235 Direction of Rotation Selector Replacement: adım 4, 2 resimden 1. Ryobi P235 Direction of Rotation Selector Replacement: adım 4, 2 resimden 2.
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
    FixBot'a Sor
    Yorum Ekle
  5. Ryobi P235 Direction of Rotation Selector Replacement: adım 5, 2 resimden 1. Ryobi P235 Direction of Rotation Selector Replacement: adım 5, 2 resimden 2.
    • Open the housing with the data label facing up.
    FixBot'a Sor
    Yorum Ekle
  6. Ryobi P235 Direction of Rotation Selector Replacement: adım 6, 2 resimden 1. Ryobi P235 Direction of Rotation Selector Replacement: adım 6, 2 resimden 2.
    • Lift the internal components out of the housing.
    FixBot'a Sor
    Yorum Ekle
  7. Ryobi P235 Direction of Rotation Selector Replacement: adım 7, 2 resimden 1. Ryobi P235 Direction of Rotation Selector Replacement: adım 7, 2 resimden 2.
    • Remove the gray plastic forward/reverse selector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Justin Godleski
319 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 UMass Dartmouth, Team S4-G2, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G2
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 1,305
