Ana içeriğe geç
Ryobi P235 Magnetic Tray Replacement
Neye ihtiyacın var
  1. Ryobi P235 Magnetic Tray Replacement, Battery: adım 1, 2 resimden 1. Ryobi P235 Magnetic Tray Replacement, Battery: adım 1, 2 resimden 2.
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Magnetic Tray Replacement: adım 2, 2 resimden 1. Ryobi P235 Magnetic Tray Replacement: adım 2, 2 resimden 2.
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: adım 3, 2 resimden 1. Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: adım 3, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Magnetic Tray Replacement: adım 4, 2 resimden 1. Ryobi P235 Magnetic Tray Replacement: adım 4, 2 resimden 2.
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Magnetic Tray Replacement: adım 5, 2 resimden 1. Ryobi P235 Magnetic Tray Replacement: adım 5, 2 resimden 2.
    • Open the housing with the data label facing up.
  6. Ryobi P235 Magnetic Tray Replacement: adım 6, 1 resimden 1.
    • Remove the magnetic tray from the device.
Sonuç
Paul Sousa
805 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 UMass Dartmouth, Team S4-G2, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G2
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Thanks for sharing, I was actually looking for these steps.
Mark Robert - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 300
