Ana içeriğe geç
Ryobi P235 Trigger Replacement
Neye ihtiyacın var
  1. Ryobi P235 Trigger Replacement, Battery: adım 1, 2 resimden 1. Ryobi P235 Trigger Replacement, Battery: adım 1, 2 resimden 2.
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Trigger Replacement: adım 2, 2 resimden 1. Ryobi P235 Trigger Replacement: adım 2, 2 resimden 2.
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Trigger Replacement, Trigger: adım 3, 2 resimden 1. Ryobi P235 Trigger Replacement, Trigger: adım 3, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Trigger Replacement: adım 4, 2 resimden 1. Ryobi P235 Trigger Replacement: adım 4, 2 resimden 2.
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Trigger Replacement: adım 5, 2 resimden 1. Ryobi P235 Trigger Replacement: adım 5, 2 resimden 2.
    • Open the housing with the data label facing up.
  6. Ryobi P235 Trigger Replacement: adım 6, 2 resimden 1. Ryobi P235 Trigger Replacement: adım 6, 2 resimden 2.
    • Lift the trigger mechanism and other internal components out of the housing assembly.
  7. Ryobi P235 Trigger Replacement: adım 7, 3 resimden 1. Ryobi P235 Trigger Replacement: adım 7, 3 resimden 2. Ryobi P235 Trigger Replacement: adım 7, 3 resimden 3.
    • Use a soldering iron to remove the black and red wires connecting the trigger assembly to the motor.
    • Use the soldering iron to connect the new trigger assembly to the motor.
    • Make sure the red wire connects to the lead with the red mark on it.
Sonuç
To reassemble your device, follow these instructions in reverse order starting at step 6.
2 farklı kişi bu kılavuzu tamamladı.
Paul Sousa
805 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 UMass Dartmouth, Team S4-G2, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G2
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Is the trigger what makes this a brushless motor? Is it possible for the trigger to cause the battery to drain down completely overnight?
Netgazer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 1,203
