Ana içeriğe geç
Ryobi P271 Reverse Switch Replacement
Neye ihtiyacın var
  1. Ryobi P271 Reverse Switch Replacement, Battery: adım 1, 3 resimden 1. Ryobi P271 Reverse Switch Replacement, Battery: adım 1, 3 resimden 2. Ryobi P271 Reverse Switch Replacement, Battery: adım 1, 3 resimden 3.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P271 Reverse Switch Replacement, Reverse Switch: adım 2, 1 resimden 1.
    • Remove all ten Torx screws from the drill's case.
  3. Ryobi P271 Reverse Switch Replacement: adım 3, 1 resimden 1.
    • Gently pull the casing apart.
    • Separating the casing too quickly could cause internals to become loose, and not easily seat together upon reassembly.
  4. Ryobi P271 Reverse Switch Replacement: adım 4, 1 resimden 1.
    • Remove the trigger so that it can fully expose the reverse switch.
  5. Ryobi P271 Reverse Switch Replacement: adım 5, 1 resimden 1.
    • Firmly grab the reverse switch and pull on it until it comes out of its socket.
Sonuç
nathan krehbiel
229 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G6, Barthe Fall 2019 UMass Dartmouth, Team S2-G6, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 60
Her zaman: 1,527
