Ana içeriğe geç
Ryobi P501G Blade Replacement
Neye ihtiyacın var
  1. Ryobi P501G Blade Replacement, Blade: adım 1, 1 resimden 1.
    • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi P501G Blade Replacement: adım 2, 2 resimden 1. Ryobi P501G Blade Replacement: adım 2, 2 resimden 2.
    • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
    FixBot'a Sor
    Yorum Ekle
  3. Ryobi P501G Blade Replacement: adım 3, 3 resimden 1. Ryobi P501G Blade Replacement: adım 3, 3 resimden 2. Ryobi P501G Blade Replacement: adım 3, 3 resimden 3.
    • Remove the four black screws holding the black bearing and remove the bearing itself.
    FixBot'a Sor
    Yorum Ekle
  4. Ryobi P501G Blade Replacement: adım 4, 1 resimden 1.
    • Once the black bearing is off, remove the transparent cover of the blade.
    • Once the cover is off, remove the blade.
    • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Eeshan Mishra
424 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, Maness Spring 2019 Cal Poly, Team S1-G2, Maness Spring 2019 üyesi
CPSU-MANESS-S19S1G2
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 1,522
