Giriş
If your Ryobi P501G motor is suffering from low power output or is simply not working when turned on, this guide will walk you through the steps to replace it. To complete this task no special skills are required. All you need is a T5 Torx screwdriver. This repair is straightforward and has nothing unusual about it.
Neye ihtiyacın var
Locate the screws at the top face of the saw, on the green plastic surface covering.
Neredeyse bitti!
Sonuç
