Ana içeriğe geç
Ryobi P501G Shell Replacement
Neye ihtiyacın var
  1. Ryobi P501G Shell Replacement, Blade: adım 1, 1 resimden 1.
    • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
  2. Ryobi P501G Shell Replacement: adım 2, 2 resimden 1. Ryobi P501G Shell Replacement: adım 2, 2 resimden 2.
    • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
  3. Ryobi P501G Shell Replacement: adım 3, 3 resimden 1. Ryobi P501G Shell Replacement: adım 3, 3 resimden 2. Ryobi P501G Shell Replacement: adım 3, 3 resimden 3.
    • Remove the four black screws holding the black bearing and remove the bearing itself.
  4. Ryobi P501G Shell Replacement: adım 4, 1 resimden 1.
    • Once the black bearing is off, remove the transparent cover of the blade.
    • Once the cover is off, remove the blade.
    • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
  5. Ryobi P501G Shell Replacement, Shell: adım 5, 3 resimden 1. Ryobi P501G Shell Replacement, Shell: adım 5, 3 resimden 2. Ryobi P501G Shell Replacement, Shell: adım 5, 3 resimden 3.
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  6. Ryobi P501G Shell Replacement: adım 6, 3 resimden 1. Ryobi P501G Shell Replacement: adım 6, 3 resimden 2. Ryobi P501G Shell Replacement: adım 6, 3 resimden 3.
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
Sonuç
Eeshan Mishra
424 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, Maness Spring 2019 Cal Poly, Team S1-G2, Maness Spring 2019 üyesi
CPSU-MANESS-S19S1G2
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 290
