Ana içeriğe geç
Ryobi P501G Shell Replacement
Neye ihtiyacın var
  1. Ryobi P501G Shell Replacement, Blade: adım 1, 1 resimden 1.
    • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi P501G Shell Replacement: adım 2, 2 resimden 1. Ryobi P501G Shell Replacement: adım 2, 2 resimden 2.
    • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
    FixBot'a Sor
    Yorum Ekle
  3. Ryobi P501G Shell Replacement: adım 3, 3 resimden 1. Ryobi P501G Shell Replacement: adım 3, 3 resimden 2. Ryobi P501G Shell Replacement: adım 3, 3 resimden 3.
    • Remove the four black screws holding the black bearing and remove the bearing itself.
    FixBot'a Sor
    Yorum Ekle
  4. Ryobi P501G Shell Replacement: adım 4, 1 resimden 1.
    • Once the black bearing is off, remove the transparent cover of the blade.
    • Once the cover is off, remove the blade.
    • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
    FixBot'a Sor
    Yorum Ekle
  5. Ryobi P501G Shell Replacement, Shell: adım 5, 3 resimden 1. Ryobi P501G Shell Replacement, Shell: adım 5, 3 resimden 2. Ryobi P501G Shell Replacement, Shell: adım 5, 3 resimden 3.
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
    FixBot'a Sor
    Yorum Ekle
  6. Ryobi P501G Shell Replacement: adım 6, 3 resimden 1. Ryobi P501G Shell Replacement: adım 6, 3 resimden 2. Ryobi P501G Shell Replacement: adım 6, 3 resimden 3.
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Eeshan Mishra
424 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, Maness Spring 2019 Cal Poly, Team S1-G2, Maness Spring 2019 üyesi
CPSU-MANESS-S19S1G2
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 692
