Ana içeriğe geç
Ryobi P501G Trigger Replacement
Neye ihtiyacın var
    1. Ryobi P501G Trigger Replacement, Shell: adım 1, 3 resimden 1. Ryobi P501G Trigger Replacement, Shell: adım 1, 3 resimden 2. Ryobi P501G Trigger Replacement, Shell: adım 1, 3 resimden 3.
      • Remove the three screws on the inside base of the metal casing of the blade.
      • Pull the metal blade casing off of the Ryobi P501G body.
      FixBot'a Sor
      Yorum Ekle
    2. Ryobi P501G Trigger Replacement: adım 2, 3 resimden 1. Ryobi P501G Trigger Replacement: adım 2, 3 resimden 2. Ryobi P501G Trigger Replacement: adım 2, 3 resimden 3.
      • Remove all of the screws located on the right side of the saw.
      • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
      • Pull back the shell to access the housed parts underneath.
      FixBot'a Sor
      Yorum Ekle
    1. Ryobi P501G Trigger Replacement, Trigger: adım 3, 1 resimden 1.
      • After opening the shell, locate the black plastic trigger on the handle of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Ryobi P501G Trigger Replacement: adım 4, 1 resimden 1.
      • Remove the black wiring and the trigger is free! Reposition it however you'd like or switch it out with a new one.
      • Make sure the trigger is snug and exactly where you want it. A dislodged trigger can be very dangerous in a power saw!
      FixBot'a Sor
      Yorum Ekle
Sonuç
Sophia Arias
255 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, Maness Spring 2019 Cal Poly, Team S1-G2, Maness Spring 2019 üyesi
CPSU-MANESS-S19S1G2
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 32
Her zaman: 2,113
