Ana içeriğe geç
Ryobi P516 Top Case Replacement
Neye ihtiyacın var
    1. Ryobi P516 Top Case Replacement, Top Case: adım 1, 2 resimden 1. Ryobi P516 Top Case Replacement, Top Case: adım 1, 2 resimden 2.
      • Using the 5mm hex key included at the base of the saw, loosen the set screw at the front of the saw.
      • The front guard will now slide out from the front of the saw.
      FixBot'a Sor
      Yorum Ekle
    2. Ryobi P516 Top Case Replacement: adım 2, 3 resimden 1. Ryobi P516 Top Case Replacement: adım 2, 3 resimden 2. Ryobi P516 Top Case Replacement: adım 2, 3 resimden 3.
      • Remove the two 10mm T20 Torx screws from the front of the saw.
      • Pull out the front plate.
      FixBot'a Sor
      Yorum Ekle
    3. Ryobi P516 Top Case Replacement: adım 3, 3 resimden 1. Ryobi P516 Top Case Replacement: adım 3, 3 resimden 2. Ryobi P516 Top Case Replacement: adım 3, 3 resimden 3.
      • Start at the middle of the device and begin to pry up the rubber grip.
      • Pull the rubber portion inside out towards the front of the saw.
      FixBot'a Sor
      Yorum Ekle
    4. Ryobi P516 Top Case Replacement: adım 4, 1 resimden 1.
      • Remove all twelve 14mm T20 Torx screws from the main case of the device.
      FixBot'a Sor
      Yorum Ekle
    5. Ryobi P516 Top Case Replacement: adım 5, 3 resimden 1. Ryobi P516 Top Case Replacement: adım 5, 3 resimden 2. Ryobi P516 Top Case Replacement: adım 5, 3 resimden 3.
      • Remove the four 35mm Phillips #2 screws.
      • Pry the two case halves apart starting at the middle of the saw.
      • Watch out for any loose parts from inside the saw that may fall out during this step.
      FixBot'a Sor
      Yorum Ekle
    6. Ryobi P516 Top Case Replacement: adım 6, 1 resimden 1.
      • Continue splitting the case until the top piece of the case is free and set it aside.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
P516 blade locking parts
Bill clark - Yanıt Paylaş
P516 blade locking parts breakdown, please ?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 43
Her zaman: 5,502
