Ana içeriğe geç
Ryobi P517 Housing Assembly Replacement
Neye ihtiyacın var
  1. Ryobi P517 Housing Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Position the saw so you can access the button-clips on both sides of the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi P517 Housing Assembly Replacement: adım 2, 3 resimden 1. Ryobi P517 Housing Assembly Replacement: adım 2, 3 resimden 2. Ryobi P517 Housing Assembly Replacement: adım 2, 3 resimden 3.
    • Press and hold the button-clip on both sides and take the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Ryobi P517 Housing Assembly Replacement, Housing Assembly: adım 3, 1 resimden 1.
    • Lay the saw flat so the left side is facing up.
    • Remove the grey orbital button by twisting it counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  4. Ryobi P517 Housing Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the rubber boot from the device by peeling it from back to front.
    FixBot'a Sor
    Yorum Ekle
  5. Ryobi P517 Housing Assembly Replacement: adım 5, 1 resimden 1.
    • Flip the saw so its right side is facing up.
    • Remove the 10 mm screw using a Torx T27H screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Ryobi P517 Housing Assembly Replacement: adım 6, 1 resimden 1.
    • Grab the black shoe assembly and pull it out from the front of the saw.
    FixBot'a Sor
    Yorum Ekle
  7. Ryobi P517 Housing Assembly Replacement: adım 7, 2 resimden 1. Ryobi P517 Housing Assembly Replacement: adım 7, 2 resimden 2.
    • Remove the two 12.5 mm screws from the front of the guide plate using the Torx T10H screwdriver.
    • Then remove the guide plate.
    FixBot'a Sor
    Yorum Ekle
  8. Ryobi P517 Housing Assembly Replacement: adım 8, 1 resimden 1.
    • Use the Torx T15H screwdriver to remove the eleven 18.1 mm screws from the housing assembly.
    FixBot'a Sor
    Yorum Ekle
  9. Ryobi P517 Housing Assembly Replacement: adım 9, 2 resimden 1. Ryobi P517 Housing Assembly Replacement: adım 9, 2 resimden 2.
    • Refer to the diagram provided to identify the gear case.
    • Use a Torx T15H screwdriver to remove the four 30.7 mm screws that are holding the housing assembly with the gear case assembly and gear case cover.
    FixBot'a Sor
    Yorum Ekle
  10. Ryobi P517 Housing Assembly Replacement: adım 10, 2 resimden 1. Ryobi P517 Housing Assembly Replacement: adım 10, 2 resimden 2.
    • Pull apart the two sides of the housing.
    • If the housing assembly does not come apart easily, do not try to force the pieces apart or else you may damage it. Ensure that all screws have been removed.
    FixBot'a Sor
    Yorum Ekle
  11. Ryobi P517 Housing Assembly Replacement: adım 11, 2 resimden 1. Ryobi P517 Housing Assembly Replacement: adım 11, 2 resimden 2.
    • Refer to the diagram on the device page to locate the trigger-switch, circuit board, and contact plate assembly. Each of these parts is connected by wires.
    • Remove the switch, circuit board, and contact plate holder assembly from the housing assembly.
    • Gently remove the switch by taking out the wiring from the assembly. Rough handling of the wiring could damage it and require it to be replaced.
    FixBot'a Sor
    Yorum Ekle
  12. Ryobi P517 Housing Assembly Replacement: adım 12, 2 resimden 1. Ryobi P517 Housing Assembly Replacement: adım 12, 2 resimden 2.
    • Lift and remove the gear case from the housing assembly and ensure that there are no parts remaining in housing assembly.
    • Ensuring the motor remains attached to the gear case to ease reassembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Abner Fernandez
445 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 46
Her zaman: 469
