Ana içeriğe geç
Ryobi RJ1861V Assembly Bar Bearing Replacement
Neye ihtiyacın var
  1. Ryobi RJ1861V Assembly Bar Bearing Replacement, Saw Bar Assembly: adım 1, 1 resimden 1.
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Assembly Bar Bearing Replacement: adım 2, 2 resimden 1. Ryobi RJ1861V Assembly Bar Bearing Replacement: adım 2, 2 resimden 2.
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Assembly Bar Bearing Replacement: adım 3, 1 resimden 1.
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Assembly Bar Bearing Replacement: adım 4, 1 resimden 1.
    • Use a Torx T5 screwdriver to remove the four screws on the top.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Assembly Bar Bearing Replacement: adım 5, 1 resimden 1.
    • Remove the backside panel.
  6. Ryobi RJ1861V Assembly Bar Bearing Replacement: adım 6, 1 resimden 1.
    • Unscrew the four T5 Torx screws that are holding the assembly bar in place.
  7. Ryobi RJ1861V Assembly Bar Bearing Replacement: adım 7, 1 resimden 1.
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Assembly Bar Bearing Replacement, Assembly Bar Bearing: adım 8, 1 resimden 1.
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Assembly Bar Bearing Replacement: adım 9, 1 resimden 1.
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Assembly Bar Bearing Replacement: adım 10, 1 resimden 1.
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 370
