Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Unscrew the screw holding the shoe in on the back side:
    • Unscrew the screw holding the shoe in on the back side:
    • One 8 mm Torx T5 screw
  2. Begin to remove  rubber sleeve. You may have to use some force as it has a tight fit. Indicated in the photo below is the rubber sleeve removed.
    • Begin to remove rubber sleeve. You may have to use some force as it has a tight fit.
    • Indicated in the photo below is the rubber sleeve removed.
  3. After sleeve is removed begin to remove the six screws on the back of the device.
    • After sleeve is removed begin to remove the six screws on the back of the device.
    • Six Torx T5 Screws
  4. Using a screw driver begin to unscrew the 4 screws on the top. There will be two screws on each side of the device.
    • Using a screw driver begin to unscrew the 4 screws on the top. There will be two screws on each side of the device.
    • Four Torx T5 Screws
  5. Remove the backside panel to expose the internal components.
    • Remove the backside panel to expose the internal components.
  6. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  7. Unscrew the four T5 Torx screws that are holding the assembly bar in place.
    • Unscrew the four T5 Torx screws that are holding the assembly bar in place.
  8. After all screws removed, the assembly bar can be removed and replaced with ease.
    • After all screws removed, the assembly bar can be removed and replaced with ease.
  9. Begin with the top of the device facing up.
    • Begin with the top of the device facing up.
  10. Insert needle nose pliers to remove the retaining pin at the top of the bearing.
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  11. Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
  12. After following prerequisite guides to get to the presented step, remove motor assembly from back housing. Motor Assembly will be greasy
    • After following prerequisite guides to get to the presented step, remove motor assembly from back housing.
    • Motor Assembly will be greasy
    • Motor Assembly
    • Motor Assembly Housing
  13. Using  pliers to grab onto the elongated aluminium exterior of the housing, begin to slowly wiggle the motor assembly housing until it comes loose.
    • Using pliers to grab onto the elongated aluminium exterior of the housing, begin to slowly wiggle the motor assembly housing until it comes loose.
  14. Detach red wires from base of the back of the housing .
    • Detach red wires from base of the back of the housing .
  15. After the wires have been detached it should be relatively easy to remove and replace the Motor Assembly Housing
    • After the wires have been detached it should be relatively easy to remove and replace the Motor Assembly Housing
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 35
