Ana içeriğe geç
Ryobi RJ1861V Motor Housing Replacement
Neye ihtiyacın var
  1. Ryobi RJ1861V Motor Housing Replacement, Trigger Assembly: adım 1, 1 resimden 1.
    • Use a Torx T20 screwdriver to remove the nine 16.5 mm screws around the trigger assembly.
  2. Ryobi RJ1861V Motor Housing Replacement: adım 2, 2 resimden 1. Ryobi RJ1861V Motor Housing Replacement: adım 2, 2 resimden 2.
    • Use a Torx T20 screwdriver to remove the two 16.5 mm screws near the trigger.
  3. Ryobi RJ1861V Motor Housing Replacement, Motor Housing: adım 3, 1 resimden 1.
    • Use a Torx T20 bit or screwdriver to remove the six 19 mm screws securing the gear case cover.
  4. Ryobi RJ1861V Motor Housing Replacement: adım 4, 2 resimden 1. Ryobi RJ1861V Motor Housing Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #2 bit or screwdriver to remove the four 37 mm screws from the top and the bottom of the gear case.
    • Once these 4 screws are removed, you have access to the motor assembly.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 103
