Ana içeriğe geç
Ryobi RS290G Brush Assembly Replacement
Neye ihtiyacın var
  1. Ryobi RS290G Brush Assembly Replacement, Top Cap: adım 1, 1 resimden 1.
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Brush Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Brush Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the top cap.
  4. Ryobi RS290G Brush Assembly Replacement, Switch Trigger: adım 4, 1 resimden 1.
    • Remove the switch trigger.
  5. Ryobi RS290G Brush Assembly Replacement, Brush Assembly: adım 5, 2 resimden 1. Ryobi RS290G Brush Assembly Replacement, Brush Assembly: adım 5, 2 resimden 2.
    • Slide the power switch out of the housing assembly by carefully gripping the power switch and slide upward from the base.
  6. Ryobi RS290G Brush Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  7. Ryobi RS290G Brush Assembly Replacement: adım 7, 1 resimden 1.
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  8. Ryobi RS290G Brush Assembly Replacement: adım 8, 1 resimden 1.
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  9. Ryobi RS290G Brush Assembly Replacement: adım 9, 2 resimden 1. Ryobi RS290G Brush Assembly Replacement: adım 9, 2 resimden 2.
    • Slide out both brush assemblies from the inner housing assembly.
  10. Ryobi RS290G Brush Assembly Replacement: adım 10, 1 resimden 1.
    • Slide off the disconnect terminal for the brush assembly (white lead).
  11. Ryobi RS290G Brush Assembly Replacement: adım 11, 1 resimden 1.
    • Slide off the disconnect terminal for the brush assembly (black lead).
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 728
