Ana içeriğe geç
Ryobi RS290G Power Switch Replacement
Neye ihtiyacın var
  1. Ryobi RS290G Power Switch Replacement, Top Cap: adım 1, 1 resimden 1.
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi RS290G Power Switch Replacement: adım 2, 1 resimden 1.
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
    FixBot'a Sor
    Yorum Ekle
  3. Ryobi RS290G Power Switch Replacement: adım 3, 1 resimden 1.
    • Remove the top cap.
    FixBot'a Sor
    Yorum Ekle
  4. Ryobi RS290G Power Switch Replacement, Switch Trigger: adım 4, 1 resimden 1.
    • Remove the switch trigger.
    FixBot'a Sor
    Yorum Ekle
  5. Ryobi RS290G Power Switch Replacement, Power Switch: adım 5, 2 resimden 1. Ryobi RS290G Power Switch Replacement, Power Switch: adım 5, 2 resimden 2.
    • Slide the power switch out of the housing assembly by carefully gripping the power switch and sliding upward from the base.
    FixBot'a Sor
    Yorum Ekle
  6. Ryobi RS290G Power Switch Replacement: adım 6, 3 resimden 1. Ryobi RS290G Power Switch Replacement: adım 6, 3 resimden 2. Ryobi RS290G Power Switch Replacement: adım 6, 3 resimden 3.
    • Slide the red and black leads from the power switch using a spudger.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. After reassembling, perform an operational check before using.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 28
Her zaman: 1,153
